It is currently Sat Aug 09, 2025 12:29 am
PostPosted: Mon Aug 24, 2009 2:40 pm
So, is there any use for an ocilliscope in acoustic guitar making? Can it be used to measure modulous of elasticty and stuff like that (you speed of sound through wood?). Any good references would be appreciated! (I know nothing about these things but just bought one!)
PostPosted: Mon Aug 24, 2009 3:04 pm
Good question! I have an old Dumont Cathode Ray Oscillograph, that works just fine, but it's pretty much a cinder block in my hands. I haven't a clue what to use it for. I tried to use it for biasing amps some years ago, but never got that right either. It was too easy to just do it with a meter.
PostPosted: Mon Aug 24, 2009 4:44 pm
Uses in guitar building - I'm not sure. I have several and also use them at work so I certainly know how to use them and what they can do but I have yet to see a reason to drag one down to the shop, at least for acoustic building.
PostPosted: Mon Aug 24, 2009 5:19 pm
First name: Jimmie (Jim)
Last Name: Hall
City: Columbia
State: SC
Zip/Postal Code: 29223
If you have some backs that are potato chipping, stack them up and set the Dumont on top. After a few months they might straighten out.
If you can't do something well, learn to enjoy doing it poorly.
PostPosted: Mon Aug 24, 2009 5:27 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Jim has it about right. You could put it under your bench and leave it on during cold spells - it will warm the air around your feet nicely. That's about all it's good for IMO. beehive
Dave F.
Cambrian Guitars
PostPosted: Mon Aug 24, 2009 7:08 pm
First name: Erik
Last Name: Hauri
State: Maryland
Wood density is sometimes used as a proxy for the speed of sound in wood - they are roughly correlated. 20 MHz may not be quite fast enough, but more than once I've thought of using a fast scope to directly measure the speed of sound in wood billets (I have a 1 GHz one at work).
You need dual piezo elements fed into separate channels of the scope, one element at each end of the board. Bonk on one end and you'll get 2 pulse arrivals on the scope, separated by the time it takes the sound wave to travel from one end of the board to the other. You can measure the time difference between pulses down to a few nanoseconds on a good scope. Length of board divided by time = speed of sound.
At least in theory - I haven't tried it. beehive
The member formerly known as erikbojerik....
PostPosted: Mon Aug 24, 2009 10:34 pm
Thanks Erik. That is kind of what I was thinking about. I don't have an idea how to do it but I thought that a scope was useful for that purpose as I had rad it somewhere, maybe from Siminoff. This is a Tektronix and I was also wondering if 20Mhz was enough, if not I guess I will use it for other purposes of some kind or another or something!
PostPosted: Mon Aug 24, 2009 10:41 pm
You can measuire the speed of light with that, I imagine it could handle the speed of sound.
PostPosted: Tue Aug 25, 2009 1:48 am
Last Name: Shaw
City: Philadelphia
I have one and it comes in handy so much that i forget where i actually stashed it. idunno I use to tinker with electronics so thats why i have it. You can actually tune a guitar with it. But since most here have a guitar tuner laying around whats the point since it's no easy process.
PostPosted: Tue Aug 25, 2009 7:22 am
First name: Erik
Last Name: Hauri
State: Maryland
As I remember I think it actually comes down to the sampling frequency, which on my work scope is 5 gigasamples/second. I can measure time differences approaching a nanosecond. But this is a fairly new digital scope - if yours is an older analog model, it may not be up to the task.
PostPosted: Tue Aug 25, 2009 11:59 am
Various sources seem to agree that the speed of sound through wood (along the grain) varies around 5,000 m/s. Assuming you test a piece along the grain that is 1/2 meter in length then the sound should take 1 s/5000m x 0.5 = 100 microseconds per 1/2 meter (approximately). A 20Mhz scope should be able to measure this quite easily.
If the scope does not have a single-shot function then using a "bonk" won't work well. It would be easier to use the piezo element on one end to inject a tone and then use a piezo element on the other end to receive the tone. Then you can use the scope to measure the relative phase difference and calculate the time.
PostPosted: Tue Aug 25, 2009 2:57 pm
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
I think it might be fun to mechanically attach a low mass LVDT (Linear voltage differential transmitter) or a piezo electric crystal to the top of the guitar and measure the movement of the top with the scope while striking notes. As the frequencies of the notes are known, comparing the vibration data of the top might be kind of cool. I might give it a try once it gets cold around here....food for thought from a geek..LOL. Might be an insightful tap tuning aid as well......
John Nowicki
PostPosted: Tue Aug 25, 2009 6:52 pm
... might be kinda cool.
I wonder if that's how Al got started on his journey of inquiry?
PostPosted: Wed Aug 26, 2009 9:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If your scope is new enough (Digital) you should be able to hook it to a computer to store the data.
Users browsing this forum: Bing [Bot] and 42 guests
